TStat removal
Mar 29, 2013 | 01:08 PM
TStat removal
I'm replacing the thermostat and water pump today. How do I remove the tstat from the housing? Do I need a special tool to remove or install? Thanks!
Mar 29, 2013 | 02:36 PM
I don't know that you HAVE to have one of these, but it makes the job easier.
Mar 29, 2013 | 02:37 PM
Mar 29, 2013 | 05:12 PM
All you need is a couple of stubby screwdrivers to push down on the tabs of the thermostat and then rotate it a bit. It comes right out.
Mar 29, 2013 | 05:24 PM
Thanks for the help. I was able to get it with two pointed nose pliers.
