996 Forum 1999-2005
Brake flush question
Old Mar 28, 2013 | 09:40 PM
Zanzibar Red 996's Avatar
Zanzibar Red 996
Default Brake flush question
Planing a brake flush using a presserized system from
Prlican parts . Can I do one wheel off at a time ?
(I'm limited to one small jack)
Old Mar 28, 2013 | 10:29 PM
Ubermensch's Avatar
Ubermensch
Yes, that's typically how it's done. Passenger rear, driver rear, passenger front, driver front in that order.
Old Mar 28, 2013 | 10:31 PM
Viper6's Avatar
Viper6
Yes you can... it will take awhile though as I did it this way my first time and polished the wheels while it was off. Going forward I'll put on 4 jack stands and take off all 4 wheels and move thru it quicker.
Don't forget to bleed the clutch too! Definitely put car on jack stands first since you will be under the vehicle... bleed valve accessed from drivers side on top of the transmission! Good luck
Old Mar 28, 2013 | 10:38 PM
Sneaky Pete's Avatar
Sneaky Pete
I have done that way too.....just make sure you keep the pressure up while bleeding about 15 PSF and don't run the resoviuor (sp?) dry.
Old Mar 28, 2013 | 11:57 PM
Zanzibar Red 996
Thanks all
Old Mar 29, 2013 | 02:44 AM
white out's Avatar
white out
You don't even need to take the wheels off. You just need access to the bleeders. Get some 3/16" hose, a Motive bleeder, and you're money.
Old Mar 29, 2013 | 07:46 AM
sf66's Avatar
sf66
Exterior bleeder first, interior second. You proceed from the outermost to the closest. Don't let brake fluid seep on the paint, it'll eat it even on the rims.
If a bleeder's stuck, break it sligthly loose with a 11mm socket (IIRC) before opening it with the piping wrench. You could damage the bleeder with the wrench if it's stuck.
