996 Engine Problem - Tapping Noise - Engine Swap Required?
I have a 2004 996 with 83K that runs well. A tapping noise has become more pronounced of late to I went to the dealer for a diagnosis. It appears that one of the cylinders is scored and a swap for a rebuilt engine is required. For some reason the car was also low on coolant last month. I will get a second opinion, but here in Canada it's going to be a $28k cost. Any alternatives?
Find a used engine from a salvage car that got front/side impact damage and written off.
Take you chances on a ebay rebuilt engine.
I have a hard time believing that a scored cylinder is causing a tapping noise. Any other issues other then the noise (ie. exhaust smoke, poor idle, misfiring)? Did the shop do a leakdown and get poor results on that cylinder? If that is the case, get the cylinder wall inspected with a boroscope.
You could just have carbon buildup under one of the valves. This would cause poor leakdown results and increased valve lash, which produces a tapping sound. As for the coolant loss that could be anything in the system. Get the cooling system pressure tested and find out where it is leaking.
Parts Specialist
yea...you have to get a second opinion....
scored cylinder? - never heard that one
stuck lifter
cracked lifter cradle
broken valve spring
these sound more likely
did they bore scope the suspect cylinder?
(because I have seen one that had something impailed into the top of the head...that until broken down we will not know what it is, but suspect part of a ring?)
time for a second opinion, or some bore scope pics
stuck lifter
broken valve spring
That is funny, scored cylinder is more common then IMS.
This is interesting reading about it.
part 4 and part 5
http://www.hartech.org/buyers.html
I have one and it taps. Spark plugs pulled and borescoped to find that #4 is scored.
Here is my engine noise, noisy at 1100 rpm. RPM range in the Video is from 800-2000
part 4 and part 5
Parts Specialist
HMMM...I seriously have not paid that much attention to that - but will keep my eyes, and ears out for it - I agree with your comments about the 3 letter acronym - but it is something that can be fixed in the cars - and doesnt cost much - worn cylinders - not so much.....
thanks for the video reference
part 4 and part 5
part 4 and part 5
My bet would be on a stuck lifter making that noise. The scored cylinder amy cause somewhat lower compression #s on that cylinder but may not be the issue related to the noise. Especially if the engine runs strong.
Other symptoms are the catalytic converters needing to be replaced every 1.5 years but the car has been burning through cats since I got it in 2003.
