FS: 03' 996-3.6 Motor Just Refreshed....
Posting for my wrench, Speed Gallery in North Hollywood, Ca.
Price: $9,500 w/rebuildable core, $11,500 w/o core.
Customer's car that is installing a new DFI 3.8. I drove this motor in the original car before it was pulled and refreshed and it ran perfectly. It only has 33k orig miles on it but they pulled the heads and refeshed them along with the all the bearings, etc. including the IMS. This was going to be my new motor but I've since found a 3.8 I'm going to use. This motor is complete with all accessoeries including the air conditioning compressor. 12month/12k mile warranty included.
Call Dan at (818) 822-5246
danaspesi@gmail.com
danaspesi@gmail.com
I mean was there any sign of problem that pushed do that work ?
I wonder what head refresh and bearing mean as well... more by curiosity than anything else, but if you want to enlight us Because I had to idea there was bearing that could/should be replaced in the heads
Phil it's going into a race car.
Agreed there was probably no reason to refresh other than it's relatively easy to do so when it's out of the car and makes selling the motor a little easier, especially with a guarantee. Bearings are rod and mains...
oh even the rods are changed, quite deep refresh then..
nice.
if only it was a 3.8 I would entertain the idea in a much different way
Anyways listing the mods / refresh parts, might help value this better and interest more buyers.
GLWS
nice.
GLWS
One question though, is variable timing affected in anyway due to the different variocam setup or does that not come into play here?
ECU reprograming and/or switches are used to make a "window" of RPM that will allow Variocam to work as needed. It's been done many times, not a new thing.
I guess I meant in more terms of any mechanical issues you might face in terms of any compatibility although it is completely isolated to the head, I was just wondering if there were any gotcha's anywhere for the system.
two different fuel systems -- I think the 3.6L has a return. Not that if couldn't be over come.
Mike
Mike
Actually, the 2002 3.6liter was the first year for the NON-return fuel system, but that's easy to retrofit as needed either way. Just time and $$$ and really not bad at all to do.
Just reach down in the tank and pull the return fuel pump.....
