Engine Mount Upgrade - Benefit(s)?
A lot of you guys have upgraded your engine mounts, and everyone seems happy they did. But I don't see much about the benefit(s) -- why do it?
The cons.... Raises the engine since the bladder of the original mounts is changed for a solid rubber bushing. No big deal if you're car is lowered. Also, sharp expansion joints will be very noticeable compared to the dampening you get with oe mounts.
For a track guy, the semi-solid mounts are a no brainer. For the casual street driver i wouldn't recommend them.
I think you meant to say: "Thanks for being an a$$hole..." My remark wasn't the most helpful, I know.
Cliffs Notes from couple other threads on this:
Improved Shifting
More solid cornering
Better launching
Better feel in threshold braking
It kinda feels like you got new suspension back there would be the way I would describe it.
This is based on the aftermarket Corteco branded mounts which appear to be slightly stiffer than OEM. I wouldn't bother just swapping to new OEM mounts unless yours are shot(leaking or sagging).
Poly mounts would introduce slightly more NVH but as mentioned above, would offer an even better feel, albeit for more track focused performance.
You're Welcome.
Improved Shifting
Better launching
You're Welcome.
Im on the market for motor mounts as we speak, i read that the oem turbo mounts are a little stiffer, is that true?
also Im looking to stiffen things a bit, i dont track the car but love performance, etc.
do semi solid mounts add too much NHV or not?
thanks
thanks
Harshness - some
Vibration - very little
Never tried turbos. From the looks of them I don't think you could feel a noticeable difference. RS on the other hand gives definite stiffer ride.
thanks guys, that answers my question,
now which of the semisolid mounts do you recomend and where can i get them at the best price and customer service!
Im planing of ordering them today,
thanks
thanks
yep...dealer just removed the old mounts with 109,500 miles on them and i replaced them with the turbo mount...not much at all...didn't even raise the driver's side exhaust tip back up....guess i'll have them adjust it up for me...the old mounts were 1/2 longer than the new one though...i got that and the trans. serviced (new fliud) at the same time...it does shift better!
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Improved Shifting
Better launching
You're Welcome.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Improved Shifting
Better launching
You're Welcome.
