Stoptech Rotors on Stock C2 Calipers
Hi,
I was wondering if you can install Stoptech 328mm X 28mm 2 piece rotors and continue to use the stock calipers?
Does anyone know the stock rotor size for a C2? I believe they are 317mm x ?mm
Does going to a wider/maybe thicker rotor affect pad size?
My main goal is to reduce weight and go slotted rotors.
I have the Stoptech rotors from a parts collection and would rather use them if possible. My other option is to buy the performance friction 2 piece direct replacement for 996 C2.
Thanks!
PS - i have searched for hours on rotor sizes, did not find much useful info. thanks again.
Thanks!
Former Vendor
We carry OEM replacement slotted rotors that fit the C2 much cheaper the the PFC 2 piece units. If you have the Stoptech units and really want to fit them on your car.... Confirm this first... Is the offset the same as OEM? If so, we can make you a spacer (that would fit under your calipers)and supply longer bolts that permit your Stoptech units to work.
