996 Forum 1999-2005
996 C2 or C4. My wife is all concerned about traction.
Old 12-07-2012 | 04:13 PM
brad@tirerack.com's Avatar
brad@tirerack.com
Former Vendor
Originally Posted by wwest
"Snow" tires are TOTALLY worthless unless the surface is loose enough for the tread to sink into, penetrate slightly. On packed snow or ice you will be much better off with standard summer tires with more tread surface area for the surface contact patch.
Wrong. The compound of a winter tire allows it to stay pliable in very cold conditions. This is so the tire can still grip the road when frozen. The added siping of the tires allows them to grip as well. Summer only tires have larger tread blocks for summer grip, but that does little for grabbing and pulling in the snow. If you were to take a new summer-only tire out on a 10 degree morning and do the same thing with them as a snow tire, you'll soon see that snow tires will run circles around them for grip. This is indisputable not only within the tire industry, but also those here who know the difference between the two.
Old 12-07-2012 | 04:15 PM
brad@tirerack.com
Former Vendor
Originally Posted by mrhebert
......A rear ender will absolutely ruin your day,month, year, and your Porsche will never have the same value when the Carfax reads "accident repair!"
...probably from people trying to use summer-only tires.
Old 12-07-2012 | 04:34 PM
WalterRohrl's Avatar
WalterRohrl
Originally Posted by KrazyK
Or,, a C4S would solve your issue.
I don't think so. Go out in ice or snow in that C4S with your standard high-performance summer tires and you will quickly find yourself with damage. AWD is not a cure-all, a purpose made snow/winter tire is.
Old 12-07-2012 | 04:38 PM
WalterRohrl
My Porsche doesn't go out in that kind of weather, my F/awd RX300 does. The RX300 runs all year 'round on the most comfortably riding, quietest summer times I can fit, tire chains at the ready...always.
What tires do you run? I doubt it's a "Summer" tire. More likely some kind of all-season that performs OK and gives that cushy ride, but a set of real "summer" tires and a set of real "winter" tires would improve the car in terms of handling during the summer and everything during the winter.
Old 12-07-2012 | 05:41 PM
Sneaky Pete's Avatar
Sneaky Pete
My car is a DD with Michelin Super Sports in the Summer and Pirelli Snosport 240's. The correct tires are key no matter what you drive. My C4 has saved my butt more times than I care to say. I really prefer the 4 over the 2. With PSM (standard on a C4 it tells you when you are doing the wrong inputs. The more you drive the less the PSM comes on = faster in Summer and Snow. Do I drive like a maniac..nope. But it sure is nice to know how your car reacts in special circumstances.
Old 12-07-2012 | 05:43 PM
perfectlap's Avatar
perfectlap
I know this to be untrue because I lived it. One year I was lazy in switching over to the snows, still had the summers on after Turkey day. We got a flash freeze after rain one night, I attempted to drive home from NYC where it's often few degrees warmer -- no ice. What a mistake. Once I was into colder weather I could barely keep the car on the road. I had to dump it until the temps came back up the next day. Promptly switched over to the the snows on my winter wheel set, no problems at all when the temps dropped again. Wet weather performance also magnifies the cold weather issue of useless summer tires.
To the OP, I also don't at all care for all season tires on performance cars.
Car feels numb in summer, useless if you get caught out with heavy snow.
Probably fine in a Corolla.
Old 12-07-2012 | 08:44 PM
wwest's Avatar
wwest
So..? And by what margin...? What is the traction factor on "hard" ice of a winter tire vs that of a true summer tire...??
Proof...?
Siping is of no help whatsoever if the tire cannot "sink" into the surface.
Agreed.
And if the surface is so slippery and hard that there's nothing to "grab"..?
Try that on an ice rink and who wins..?
Ask yourself....What's the effectiveness of ABS for stopping AND stearing on an ice rink with winter tires vs summer tires...?
Old 12-07-2012 | 08:49 PM
wwest's Avatar
wwest
Bridgestone Turanzas.
My RX tire chains work in ALL wintertime conditions whereas wintertime tires only function with a "soft", penetrable surface.
Old 12-07-2012 | 09:20 PM
fpb111's Avatar
fpb111
They already have. Take a look. Please show us a comparison with your instrumented testing.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=167
"...To find out what sort of handling and traction the newest and best Studless Ice & Snow tires deliver, the Tire Rack team conducted a Real World Road Ride and Ice Rink Drive. We compared the new Michelin X-Ice Xi3 with the Goodyear Ultra Grip Ice WRT and two of the best already available in the category -- the Bridgestone Blizzak WS70 and Continental ExtremeWinterContact. Our evaluation used 2012 BMW F30 328i sedans fitted with new, full tread depth 215/60R16 tires mounted on 16x7.5 wheels..."
Old 12-08-2012 | 05:52 AM
speed rII's Avatar
speed rII
C2 in snow? No problems what so ever
Old 12-08-2012 | 09:37 AM
Van's Avatar
Van
Remember, a C4, at most can only give 30-40% of power to the front wheels (to make it behave like a rear-wheel drive car) - so it's not quite as "4WD" as a jeep.
As other people have said, a C2 on winter tires will be much better than a C4 on all-season.
There is no substitute for good winter tires.
I went through the same thought process when I got my car - and I did get a C4, but if I had to do it again, I wouldn't have made that a deal breaker.
One important thing to remember is that the C4 came standard with PSM - which can offer a certain amount of "piece of mind".
Old 12-08-2012 | 10:51 AM
Black_on_black's Avatar
Black_on_black
Following Van's last post, the PSM on my car certainly helps out in slippery wintery conditions. Recent example from last week I was going round eg suburban 15mph 90 degree corners it is natural to rlease power, engine brake and the back will come around if not being careful, PSM helps even here! I see it flicker and hear it brake outside corners etc. I have Pirelli Snowsport 240's which is a true winter tire. Turning off PSM typically means a little sloppiness and backwards u go
BTW it is 20" snow and 10F here.
Old 12-08-2012 | 11:09 AM
ivangene's Avatar
ivangene
Parts Specialist
Originally Posted by Hardback
My friend, you should come to the track some time. You will see that's swapping ends is easier than you think. ERME has an event next weekend at Homestead. Just saying
this is spot on - but 100% the reason to get a C2 over C4
having a car that will bite you if not driven right is better than a car that is saving your bacon all the time - but you have to learn what that means and where the edge is, how to control it, and how to drive it
put on a new set of good snow tires and a C2 is a point and shoot car --- absolutely predictable and controllable with some skills - and a real hoot to drive
plus in the summer, its more agile / lighter
Old 12-08-2012 | 01:33 PM
fpb111's Avatar
fpb111
Watch this Vid of 2 wheel drive Porsche in snow.
Old 12-08-2012 | 01:49 PM
billqj's Avatar
billqj
+1. I'm from Boulder, and when it's slick or snowy, the Porsche stays safely in the garage, and the F150 4x4 comes out.
Quick Reply: 996 C2 or C4. My wife is all concerned about traction.
