996 Forum 1999-2005
Hood Emblem - How's it attached?
Old 12-05-2012 | 04:28 AM
uswrnk54's Avatar
uswrnk54
Default Hood Emblem - How's it attached?
I was putting a coat of was on my new toy this evening. While working on the hood I was removing product from around the emblem on the hood. The emblem moved. It didn't come completely off, just rotated about 20 degrees. My quesion is, how is the emblem attached to the hood? Is there an alignment pin, or is it just adhesive? If mine moves I'm thinking I need to remove it & re-attach it.
Thanks in advance.
Old 12-05-2012 | 04:49 AM
Ahsai's Avatar
Ahsai
It's held on to the hood by two pins and spring washers. Just check out the underside of the hood. Should see two recessed holes where you can tighten the washers.
Old 12-05-2012 | 11:13 AM
ivangene's Avatar
ivangene
Parts Specialist
really crank on those things too because they are super strong and wont just snap off
NOT !!!
Old 12-05-2012 | 12:21 PM
uswrnk54's Avatar
uswrnk54
Thanks guys, I'll check it out.
Old 12-05-2012 | 01:05 PM
fpb111's Avatar
fpb111
Also don't close the hood by pushing on the hood emblem. There is no support under it. It will develop an upward curve, like a potato chip, and you can also damage the hood.
Old 12-05-2012 | 02:31 PM
ECS Tuning's Avatar
ECS Tuning
Former Vendor
If you ever need to replace your hood crest, we offer a Full Color Hood Crest Replacement Kit.
Old 12-05-2012 | 02:49 PM
yoda888's Avatar
yoda888
What's the recommended way to close the hood? Need to push down on something if you don't want to slam it.
Old 12-05-2012 | 03:06 PM
Ahsai's Avatar
Ahsai
Push on the area that's approx 1 inch below the emblem, where the hood latch is installed.
Old 12-05-2012 | 03:30 PM
kromdom's Avatar
kromdom
+100.....using the "heel" of your palm, which is about what will fit in that space anyway.
Old 12-05-2012 | 04:00 PM
uswrnk54's Avatar
uswrnk54
It's called a "fronk" from what I've gathered on Rennlist.
Old 12-05-2012 | 04:20 PM
kromdom's Avatar
kromdom
I have also seen FRUNK used
Old 12-05-2012 | 04:42 PM
dotframe's Avatar
dotframe
++Frunk
Old 12-05-2012 | 05:52 PM
MiamiC70's Avatar
MiamiC70
bubble gum
Old 12-05-2012 | 06:00 PM
AndyK's Avatar
AndyK
Everyone should watch that Hurley Heywood "welcome" video about the various need to know features of the 996! Fun to watch, and, informative.
Video #33 in the 996 section!
http://coochas.com/porsche/911vids.html
Old 12-05-2012 | 06:22 PM
fpb111's Avatar
fpb111
+1
Also use both hands to spread the load.
Quick Reply: Hood Emblem - How's it attached?
