Oil Analysis - High aluminum and iron, what does it mean?
#31
some data
Based on four oil changes and four oil analyses, here's are the facts for my '99 996 (currently w/67K miles):
mileage Al Fe
9K 7 22
5K 3 7
4-5K 3 8
5K 2 5
The oldest event is at the top and the newest is at the bottom. All changes are annual changes and fills are Mobil 1 0W/40W.
Conclusion? The data clearly suggests that long oil change intervals should be avoided to minimize wear, and 5K is about right for daily drivers.
relinuca
mileage Al Fe
9K 7 22
5K 3 7
4-5K 3 8
5K 2 5
relinuca
#32
a translation
Oops...the posting kind of messed up the columns.
To explain, 9K 7 22 means 9,000 miles on oil, Aluminum ppm is 7, and Iron ppm is 22.
The ppm could be converted to mg/kg if someone wants to do the math.
relinuca
relinuca
#33
I change the oil in my TDI every 35 000km interval and the internals are spotless. This is over twice the factory recomendation. Changing the only like a maniac, doesn't guarantee anything. I never changed the oil before the recomended interval and never had any oil related issues with any of my cars. Something worth thinking about.
When I had a TDi even after 5K miles the oil was black as the ace of spades. Normal with a diesel engine. Soot.
I can't imagine how much soot TDi oil that has been in service for nearly 4 times that many miles would contain. I'd find it hard to believe the oil's detergents could keep the soot in suspension that long.
BTW, VW changed the oil change interval for my TDi (02 Golf) from 10K miles to fewer miles -- I can't recall the miles now -- because VW USA classified the area i which I lived/drove as a harsh usage area. The area? KC MO. Seems the humidity, temp changes, and dust in the air from at various times agriculture activity led VW USA to recommend (in fact specify) more frequent oil/filter services.
How did I learn of this? No phone call from VW USA or the dealer where I bought the car. Nothing in the mail. No text message. There was a notice on the VW dealer service manager's desk, a placard/sign, stating VW USA's change in the oil change interval.
#34
There was a users ride write up in one of the UK published Porsche mags about a Cayman owner who's car smoked a bit more than normal and a borescope inspection found "scoring". Being the car was out of warranty the owner continued to drive the car and after some miles (several thousand, around 10K IIRC) the smoking was gone and the engine was running just fine.
#36
Captain Obvious
Super User
Super User
Have you torn down the engine to confirm the internals are spotless?
#37
Best cure is grab wallet after oil change and get on the trans canada hwy once in a while for long drives to keep the contaminating gasses from polluting your oil by letting the engine blow them off during the long drives. Short around town rides heat the oil good enough to create the bad oil aspects but not blow the stuff off. It takes some lengthy riding to get the stuff to gas off.
#38
Imoo
With your background you know better than to compare a diesel engine to a gasoline. Diesels run into the millions of miles without rebuild.
Diesel is a lubricant. Gasoline is a solvent. To compare the two is absurd.
#39
One of the Porsche approved oils. If you chose to run something else, to stray off the Porsche approved oils reservation, you can make your oil selection by walking into an auto parts store and tying on a blindfold at the oil aisle and using the first bottle of oil you grab.
Your choice would be about as scientific and valid as any one's off the reservation oil recommendation.
#40
Captain Obvious
Super User
Super User
You are taking things out of context. My two posts are relative to each other and are related to the discussion. But to be fair, I never change the oil ahead of the manufacturer's recomended interval either.
