996 Forum 1999-2005
Nitrogen Tires
Old Oct 13, 2012 | 03:23 PM
sjfehr's Avatar
sjfehr
Nah, it doesn't need to be stored unpressurized, it's just usually cheaper/easier since liquid nitrogen is cheap and will keep for a week or more in a dewar before evaporating completely away. It can also be stored pressurized in liquid form.
My lab in college actually had plumbing- hot water, cold water, deionized water and liquid nitrogen. If we needed liquid nitrogen, we'd just carry over a dewar (usually just plain ole styrofoam), open up the spigot and fill 'er up. Man, that was nice. Hmmm... now that I think about it, don't think it would work in practice to use the same bottle both for nitrogen gas for tires and liquid nitrogen for playing. I suppose in the end, I'd be better off just renting a dewar for a few days to play with..
Old Oct 13, 2012 | 04:19 PM
street rod's Avatar
street rod
Or just go drink some dewars and forget about it.
Old Oct 13, 2012 | 07:03 PM
jpowers's Avatar
jpowers
The new super insulated dewars will easily last over a month.
Old Oct 13, 2012 | 09:14 PM
ivangene's Avatar
ivangene
Parts Specialist
I have liquid @ work...should a smuggle out a teaspoon and get the tires to drink the cool-aid
Old Oct 13, 2012 | 11:53 PM
jordanturbo's Avatar
jordanturbo
Cardigan Millionaire
Originally Posted by Byprodriver
This is yet another of the many benefits of using pure Nitrogen. I raise the base PSI 2 lbs if filling with Nitrogen knowing the psi is less likely to rise & cause a ride disturbance. With air I have to adjust air pressure monthly, with Nitrogen I don't have to check psi. The reduced moisture helps prolong TPMS sensor life also. I realize the Nitrogen tire fill option is a big profit margin but I gladly pay $10 per tire upcharge.
That is a little rediculous. Running our entire shop off of nitrogen costs $40-60 per year, if we only did tires it would be about half that or less
Old Oct 14, 2012 | 03:00 PM
thirteeneast's Avatar
thirteeneast
LOL, Not this one again.
Nitrogen fill,
Did you also know that if you take your hard earned cash and throw it up in the air chances are the wind will blow it away.
Old Oct 14, 2012 | 03:18 PM
tooloud10's Avatar
tooloud10
Team Owner
Nitrogen fill,
Ha, that is true. There are specific advantages to nitrogen filled tires, but none worth paying for on a street car.
