996 Forum 1999-2005
Reverse lights not working.
Old Oct 9, 2012 | 05:25 PM
Hurdigurdiman's Avatar
Hurdigurdiman
Default Reverse lights not working.
My reversing lights are not working and I believe it could be a faulty reversing switch somewhere on the transmission. Has any of you had to change one? If so could you please tell me where to find the switch on the transmission and how easy/hard it was to change? Thanks.
Old Oct 9, 2012 | 08:21 PM
rb101's Avatar
rb101
I need to change mine as my backups do not work. It's located above the shiftier linkages, on the passenger side (driver side for the Brits).
Old Oct 9, 2012 | 10:22 PM
Ubermensch's Avatar
Ubermensch
It's probably the easiest thing you can replace on a 996. You can reach it without jacking up the car. You just need to lay on the ground, reach up to remove it, and then replace the new one. I think it took 5 minutes. 10 tops.
Old Oct 10, 2012 | 01:24 AM
Hurdigurdiman
Thanks UBERMENSCH:- Is it on top of the transmission or on the side or where? If that doesnt do the trick do you know if that switch then goes via a relay on the car.If so, where do i find the relay... Thats looking in advance if the switch doesnt do the trick.
Old Oct 10, 2012 | 02:36 AM
jordanturbo's Avatar
jordanturbo
Cardigan Millionaire
There is the reverse sensor on the left side of the transmission on to, about half way between the front and back made of white plastic.
Old Oct 12, 2012 | 08:56 PM
Hurdigurdiman
OK Jacked up the car from the rear, dropped it onto stands and found the switch real easily. Unplugged it. Uncrewed the switch 19m wrench. then reconnected the wires and pushed the switch manually with ignition on and reverse selected and dammit the lights worked this time. Put it back in. selected reverse, ignition switched on, and dammit they didn't work this time. Took the switch to auto zone and got a new one $28. One thing I did notice is the newer switch was harder to push down manually. I put that in and GOD it worked. So thanks to you guys another simple DIY job completed and the car passed it's annual and emission test with flying colours.
Old Oct 12, 2012 | 09:04 PM
vange_c4s's Avatar
vange_c4s
diy is good. well done. thanks for sharing
Old Oct 13, 2012 | 01:10 AM
rednerrus's Avatar
rednerrus
i need to do this as well. where can i buy a new switch?
Old Oct 13, 2012 | 07:12 AM
Hurdigurdiman
I got mine at Autozone. $28
Old Oct 13, 2012 | 11:54 AM
Invius's Avatar
Invius
Hurdi, they carried it in stock?
Thanks,
DS
Old Oct 13, 2012 | 07:04 PM
Hurdigurdiman
Thanks,
DS
They just had one in stock can you believe it.
Old Sep 16, 2014 | 04:07 PM
fmattitude's Avatar
fmattitude
Mine don't work either. They used to, but apparently according to the incredibly cranky old lady who claims I nearly ran her over whilst reversing, they now don't. (Not like she couldn't have seen the damn car moving in a reverse direction...)
This thread has helped. Part ordered, and I'll get it done over weekend
Old Sep 16, 2014 | 04:15 PM
5CHN3LL's Avatar
5CHN3LL
Dammit, suckered into commenting on a 2-year-old thread. Grr.
Old Sep 16, 2014 | 04:39 PM
Sneaky Pete's Avatar
Sneaky Pete
Dare I say..........
Old Sep 16, 2014 | 05:36 PM
5CHN3LL's Avatar
5CHN3LL
^ I drive a blacked-out GT3-look 911 with huge, blingy rims, and THIS is what tips you off?
