996 Forum 1999-2005
low oil pressure
Old Sep 30, 2012 | 01:31 PM
e7lew's Avatar
e7lew
Originally Posted by Imo000
Who is this specialist?
Who re-build the car previously
Old Sep 30, 2012 | 03:30 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I wouldn't have guessed.
Old Oct 2, 2012 | 06:11 AM
Stephen Tinker's Avatar
Stephen Tinker
Don't rely on the cars electronic pressure gauge for accurate readings - get the system checked using a mechanical gauge....
A low oil pressure @ idle is not too problematic as long as you have the correct pressure at + 3,000 rpm at normal engine running temperatures.
Old Oct 2, 2012 | 06:56 AM
e7lew's Avatar
e7lew
I checked oil pressure through Durametric pressure was very good
Except idiling .05 .04 sometimes .03
Old Oct 2, 2012 | 08:11 AM
trendy996's Avatar
trendy996
Whats normal pressures at operating temps?
Old Oct 2, 2012 | 08:52 AM
e7lew's Avatar
e7lew
at startup around 4.2 4.3 ( Because the weather is still hot these days 40c )
When the car is hot 80c
The pressure 1 bar or 1.1
When the temperature is 95c, oil pressure Needle on .05 bar
Old Oct 2, 2012 | 01:59 PM
targa996's Avatar
targa996
When my sending guage was faulty pressure reading would drop to zero for a few seconds while driving and then bounce to 5+ and stick there
Old Oct 2, 2012 | 03:11 PM
txhokie4life's Avatar
txhokie4life
Certainly could be rebuild issues.
Try a thicker oil? You don't need a 0w-40 with those temperatures.
m
Old Oct 2, 2012 | 03:45 PM
e7lew's Avatar
e7lew
Car now in rebuilding to check clearances, sensors, timing chain, oil leak
Old Oct 2, 2012 | 06:00 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
m
Thicker oil is not the answer if the bearing clearances are too large. It just gives a false sense of hope. Thicker oil or not, if the bearings are loose, they will pund themselves apart in no time.
Old Oct 2, 2012 | 08:55 PM
trendy996's Avatar
trendy996
I'm battling the same issue also. I'm leaning to the oil pump in the sump with the pick up.
http://www.renntech.org/forums/topic...-oil-pressure/
Has anyone fitted the dual pickup from a gt3?
Old Oct 4, 2012 | 06:32 AM
e7lew's Avatar
e7lew
guys
is there relation between Camshaft Adjustment; Bank 1 and low oil pressure ?
Old Oct 4, 2012 | 08:09 AM
trendy996's Avatar
trendy996
Cam adjustment works off oil pressure.
Old Oct 5, 2012 | 06:43 AM
e7lew's Avatar
e7lew
Dear trendy996
I didnt understand, do you mean NO ?
Old Oct 5, 2012 | 08:16 AM
trendy996's Avatar
trendy996
If you have low oil pressure the cam adjuster isn't going to function correctly.
