Performed boost leakdown test - leaky hose / check valve
I found a few other leaks which I was able to seal up by tightening the hose clamp or replacing a vacuum line.
I recently swapped in an IPD Plenum and a 74mm Throttle Body so I wanted to make sure I didn't have any leaks.
Would anyone mind identifying this hose and check valve? I'd like to pick up a replacement. I have a feeling the hose is the culprit, but I don't mind replacing both. It's the hose that runs to the left and has the screw-type hose clamp at the end.
Found these from the parts catalog:
6 996 110 654 72 Hose 1
7 996 110 659 70 Spacer 1
8 999 512 554 00 Hose Clamp 1
20 X 12
9 996 110 652 70 Venturi Tube 1
20 X 12
