Coilovers and... (other parts to consider with coilovers?)
So I have noticed the *** in my C4S is starting to sag ever so slightly. Eventually I would like to upgrade to some adjustable coilovers.
My question is if there is anything else that I should consider installing at the same time to ensure I don't have any challenges with alignment or handling characteristics when changing from stock?
I have a used set of TechArt Coil-overs I will part with for $750. Low price is because the front Bilstein incerts need to be replaced. Bilstein can do for about $500 I am told. Rather than fix these I put in a used set of PSS 9s my Indy sourced for me.
Depends on your Prefered Ride height.... if you go GT2 Ride height or Higher you should be fine with Stock components.
Anything lower you will need Front and Rear Lower Adjustable Controls Arms & Adjustable Toe Links and Rear Upper Adjustable Dogbones to get the geometry right for a Good Track Set-Up and Tire Wear.
Thanks for the tips guys! Im shooting for daily drive able with as much track time as i can afford so it sounds like i should consider doing more than just the coilovers.
Wow I wish I was ready to pick up the used ones you guys are offering but I won't be ready for at least a few months.
Naturally when I am ready to buy there won't be a set anywhere in the country
If I may make a suggestion for you, don't go off the deep end with mono *****, dog bones, etc., as you want to be able to still enjoy the street and that type of set-up will more likely than not be way to stiff and unforgiving for the road. Coilovers, gt3 sway bars and drop links, adjust the ride height and align and corner balance accordingly and the car will track flatter, transition weight smoother and turn-in better and you can still enjoy the ride on the street, although it will be a stiffer ride. This should also save you a couple of bucks verses going "all-in" amd setting the car up to stiff for the street. Just my suggestion. And if you are committed to making changes, start acquiring the bits and pieces as you go, rather than everything ast once. You can be install the bits whenever you are ready, this winter when most of the shops slow down. GL.
keep in mind each time you add anything to your suspension system you need a new alignment and it is costly compared to the parts. The 996 is VERY sensitive to alignment.
go for:
PSS10
tarett drop links (pricey but proven quality, only one with boots you need those on the street)
dog bones if you want to go any lower than stock, if not your camber will be to high and tire wear will be accelerated on the inside of the tire.
go for:
PSS10
My advice is to add components one at a time. This way you get to feel the difference each modification gives you. As you know, I recently added H&R coilovers and Tarret front camber plates. These mods along with an alignment and corner balance have really transformed car. My alignment specs are front camber -2.8, rear camber -2.3 front toe @ 0, rear toe @ 2 mm toe in. So far I notice some bump steer with this setup. Dog bones are next to cure this along with a stiffer front sway bar. That is as far as I will take it.
