Sloppy transmission shifter arm
My shifter is feeling very sloppy, but it's originating from the transmission side of the assembly. I circled the problematic part (not sure of the actual name - let's refer to it as the "transmission arm"). When I get under the car, I can pull it side to side and there is a lot of play in the connection to the bell housing. So when shifting, much of the fore/aft motion pushes/pulls this transmission arm before actually engaging the gears, leading to a feeling of disconnectedness.
Is there a way to tighten this transmission arm? Thanks.
How difficult is it to replace or shim bushing #17? That would remove most of the play.
Can this be done without disassembling and/or removing the transmission from the car?
