996 Forum 1999-2005
New owner, having a few problems
Old Aug 19, 2012 | 12:58 AM
MOVENU's Avatar
MOVENU
Default New owner, having a few problems
Bought a 2001 996 recently but have not been able to drive it much because of work and a few issues. The main problem I am having is that the battery dies if the car sits for as few as 2 days (the battery is only 2 months old). The following are some things I have noticed which could be the cause of the drain:
1) Anytime I turn off the car - when I turn it back on the radio memory is
erased (e.g. the presets are not remembered, etc.) so I assume the
radio wiring is not hooked up correctly
2) When I lock the car with the remote the, horn beeps twice which I read
indicated a fault with the alarm system. Not sure if that fault could be the
cause.
3) After turning off the car the lights for the hood release/trunkrelease/
seat memory buttons - all remain lit when the car is off 24/7. I assume that
is not normal but not sure what the fix would be.
Thanks in advance.
Old Aug 19, 2012 | 06:40 AM
David Clarke's Avatar
David Clarke
OK, I am guessing that you have an aftermarket stereo. I will go further to say thats its been installed incorrectly with the power wiring messed up and possibly an amplifier in there somewhere running full time... Get it checked out.
Old Aug 19, 2012 | 09:21 AM
Hurdigurdiman's Avatar
Hurdigurdiman
I agree that some idiotic PO has been messing with the electrics without knowing what the hell he was doing. Thats what pisses me off with some owners of these cars. Radio not loud enough. Muffler not loud enough. The deaf bastards. They mod themselves to death and F*** up a perfectly good car in the doing thereof. Then the next owner has to suffer the consequences. Same on mine. The inside light doesnt work as the doors are opened. There is no lock on the gas door. Did the PPI tell me about those faults. NOOOOOOOOOOOOO. Because the seller only told me the things he wanted to tell me. **** like the brakes have 30% left in them. Thats a 'red herring' as all brakes are used anyway. Thats why I say. Get an independant PPI and know everything there is to know about these cars before buying. I will run a mile if I find out that one thing has been modified from stock in my next Porche car. So thats me off the soap box till next time. I am so angry I could crush a grape.
Old Aug 19, 2012 | 09:30 AM
Shamus's Avatar
Shamus
I would assume these are all related. A circuit is open causing the alarm to double-signal and that circuit is causing the battery to drain, given the radio presets - I would focus on the radio wiring.
Old Aug 19, 2012 | 12:27 PM
MOVENU's Avatar
MOVENU
Thanks for the help. I should have mentioned it and yes you guys are correct - the
radio is aftermarket. I will look into it.
Thanks!
Old Aug 19, 2012 | 01:47 PM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
Try decaf!
Old Aug 29, 2012 | 09:00 PM
MOVENU's Avatar
MOVENU
Default It was the radio
Well you guys were right. Took it to a shop. Guy said it was wired to iginition a certain way, yada yada, the amp was permanently on draining the battery. Took him 10 minutes and problem solved. So that is one off the list. Of course the following day a new issue arose...
Old Aug 29, 2012 | 09:43 PM
Gonzo911's Avatar
Gonzo911
Rat Balls
Welcome to the marvels of German Engineering! These are awesome cars but they attract gremlins. Remember, your new car is over a decade old and new issues will arise. Embrace these quirks...and your wallet.
Old Aug 29, 2012 | 09:46 PM
TRT41's Avatar
TRT41
Originally Posted by Marc Gelefsky
Try decaf!
or ignore.
Old Aug 30, 2012 | 10:21 AM
Shark Attack's Avatar
Shark Attack
Put an amp meter on the battery and pull fuses one at a time till the draw stops. That will at least tell you the circuit the issue is on. If pulling fuses doesnt stop the draw, next disconnect the altinator amd see if that stops the draw.
