996 Forum 1999-2005
remote key getting weaker
Old Aug 13, 2012 | 06:12 AM
rednerrus's Avatar
rednerrus
Default remote key getting weaker
Hi all, Ive searched the forums and google for answers but the threads that i find never actually pin point the problem and solution for this issue. So Im just gonna ask.
I have a 996 1999
My remote key has been getting weaker and weaker (range wise).
I thought it was the remote battery but i changed the battery and it didnt make a difference.
From what Ive read it could be a number of things:
the battery, fuse, alarm module, head unit installation, etc.
Some info:
The range has always been pretty bad, like 6 feet from the car max. But from what I've read this is normal. Then I installed an aftermarket head unit, and I didn't ground the brown (i think) wire and left it on purpose because I kinda liked having the car honk when I lock it with the remote.
My battery is ok, not great, around 13 when started then goes up to just under 14.
So the question is, what is causing my remote getting weaker? And what can I do to find out and fix it?
Thanks.
Old Aug 13, 2012 | 08:14 AM
Gaspasser19's Avatar
Gaspasser19
You have described exactly my situation down to the alarm fault from the stereo. I like the beep too. Looking forward to others weighing in here.
Old Aug 13, 2012 | 08:59 AM
Cornbread's Avatar
Cornbread
Have you fixed your remote antenna length? This is a well know fault documented in Porsche TSB #9662 "Insufficient Range of Remote Control"
Google it. There are documented procedures on sites such as Renntech with pictures that will get you through this. this will greatly improve your range.
Old Aug 13, 2012 | 09:53 AM
nick49's Avatar
nick49
I believe the antenna is inside the drivers side A pillar. I remember removing the outside cover of this and tweeking it to get better range on our Boxster years ago. Search and you may find the details.
Old Aug 13, 2012 | 12:30 PM
rednerrus's Avatar
rednerrus
i havent yet, i ran across that tsb as well and bookmarked it. I am planning on doing that too, but the fact that my remote actually got weaker tells that i need to fix something else first.
Old Aug 13, 2012 | 02:51 PM
Down South's Avatar
Down South
I also have a '99. Mine was doing a similar thing with the range getting weaker, but when I replaced the battery it got much better for a few days, then began getting weak again. After two batteries, it wouldn't even last a day. My problem turned out to be the key head. I replaced it and have had no problems since.
Old Aug 15, 2012 | 03:54 AM
rednerrus's Avatar
rednerrus
hmmm i hope my indy gives me a new key head under warranty..
