Looking for a 996 dash cluster
Welp, it has really proven to be a challenge - I just wanted the clear plastic piece over the speedo gauge (mine's cracked I bought it that way) And it sure appears that the only way this will get fixed is to buy the whole used gauge cluster - If you have one, I have $100 to buy it. thanks - Jenn
Many local plastics suppliers will cut different types and thicknesses into various shapes very inexpensively. I've had this done for different projects in the past. It may be possible to have a lens cut and carefully glue it on. Remove your cluster and see if the speedo only lens is removable and use for a template.
