996 Forum 1999-2005
going to 19" wheels on a C4S ?
Old 05-13-2024, 12:49 PM
AH1963
6th Gear
AH1963's Avatar
Originally Posted by nick49
+1
all of the above plus what you will notice immediately if the rolling circumferential sizing is off much at all from front to rear, the handling will go to hell. There is more than one reason for this. First is the power transmission going to the front axle and the sensitivity of PSM. If the sizing mismatch is too great, PSM can activate in a turn and abruptly brake one wheel. This can be quite upsetting and alarming. Secondly the chassis is extremely sensitive to front and rear axle heights being matched within certain parameters. If the front or rear is raised only a few millimeters with respect to the other, the car may handle very poorly and unsafely. Finally, 19" tires in matched revolution per mile sizes are few and costly.
I have experienced the above. If you are like me, you'll need to find out for yourself.
Hi All,
I am doing a project on 996 also changing the existing wheel I want to upgrade with 19" Wheels what is the best sizes and offsets I can easily fit on my 2000 Model 911 - 996 Carrera S4
However, one Tire / Wheels supplier from USA recommended below4 Wheels:
Porsche Wheels RW06 19x8.5/19x11 5X130 Gloss Black Chrome Lip fit 997 996 911 Carrera Turbo
- Wheel Brand: Aftermarket Product
- Size: 19x8.5 Front, 19x11 Rear
- Offset: +45mm Front, +40mm Rear
- Bolt Pattern (PCD): 5X130
- Hub Bore: 71.6mm
- Finish: Gloss Black Stainless Chrome Lip
- Fit : Porsche Carrera
Wheel and Tire Package :
- Tire Size: Front : 235/35/19 Rear : 305/30/19 or 295/30/19
Your valuable advice and guidance will be appreciated.
Regards
AH1963
6th Gear
AH1963's Avatar
Hi All,
- Hub Bore: 71.6mm
Regards
Quick Reply: going to 19" wheels on a C4S ?
