Double Din bezel question
I'm finally jumping into the 21st century by adding navigation to my 2001 C4. There are several good threads regarding mounting double DIN headunits, but I still had a couple of quick clarifying questions. Mainly my question has to do with fitment of cup holders.
I've found a bezel made by Metra aka Connects2go which is specific to the 996 without cupholders. Easy enough, I'd have to remove my existing headunit and my cupholders and away I go. I don't use them often but it would be nice to have cupholders.
Several people have recommended this bezel/mounting kit
http://www.ebay.com/itm/03-05-PORSCH...item336dae5bda
Which seems to fit with the newer cupholders (rotate out instead of slide out like mine). Does anyone know if the newer cupholders can be retrofitted into 2001 models?
The ebay kit linked above seems to be an assembly of several other peoples parts (primarily Metra). Does anyone if the bezel they use is the same as the Metra unit?
Thanks,
Shawn
Thanks,
Shawn
Rat Balls
Not sure about the cup holder issue, but that's the same setup I used on my 03 and it turned out great. Lon at Euro Motorspeed is very helpful as well. Email him with your question. I am sure he knows the answer. Good luck!
That does look good...damn it, I might have to swallow my annoyance and pay the $160 for the kit.
Just as a follow up, apparently you can't switch out the cupholders unless you also change the vents and horseshoe. I'll probably just live without cupholders like generations of P-car owners before me.
I'd love to know if the bezel in that kit is from Metra like the wire harness.
"Just as a follow up, apparently you can't switch out the cupholders unless you also change the vents and horseshoe"
I think that you are correct. The vent is narrower or up higher on the 2002 and up cars which allows for the swing out style.
I would like to do what you are doing also but went with the floor aftermarket cup holders for now. Keep in mind all that liquid right above your nice double din radio![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I tried putting the pop out cup holder in the area where the CD STORAGE unit is but it did not even come close to fitting.
Now I am thinking about pulling the CD holder and coming up with something to hold my IPhone internally but easy to take out.
Rocky Mountain High
FWIW - the cup holders in the 2002+ cars suck. I hardly ever use mine. You aren't missing much.
Why would you want to put a cup of hot liquid, or filled with carbonated drink right above your new $600.00 beautiful stereo? Porsche engineers never figured out a good place to put cupholders. Amazing! Every place they tried was bad. over the stereo, in front of vents...etc.
But the Ultimate cupholder is fantastic and solved all the problems for cupholders for me. And they look great too. Anyone who poo poo's a cupholder in a Porsche needs to get real. Everyone who uses their car in the real world drinks in the car and needs a secure place to hold it. Were not racing all the time. (I have no interest in the company just a happy owner)
http://www.ultimatecupholders.com/
Rat Balls
Those German Engineers knew what they were doing. Because they put the cup holder directly in front of the air vents, my coffee stays warm in the winter with heater on, and my beverage stays cold in the summer when I run the AC.
I ended up ordering the kit from Eurospeed. I asked him directly whether or not the bezel was from Metra and he didn't answer directly. He stated that every part of the kit was custom designed to optimize fit and look. That may mean he buys Metra bezels and has "Porsche" printed on it, or it may mean he custom molded/machined his own solution. When it arrives I'll check it thoroughly for any indication one way or the other. The only Metra bezels I could find for sale were from UK Ebayers and I really didn't feel like dealing with an international return if I didn't like the look.
