2003 Porsche 996 Targa Wiring Diagram
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
My Porsche Targa has electric problem with the high low beams.
I have checked the fuses,
the voltage to the +ve terminal for the fuses w/o the fuse in place,
the continuity of the -ve terminal of the fuses to the headlight assembly female connector at the car frame,
the voltages on the female connector with the light switch on and light (high/low) level nd
the ground continuity from the 1-12 ports on the female connector at the car frame to the main ground.
The problem with the power to the low or high beam continue.
I need the wiring diagram for this car to solve the problem or if someone know a web page tha t can give me some ideas.
Thanks.
Thanks.
As described.
No low or high beam lights in either side.
High beam bulbs are ok. But, only works with the headlight lever flasher.
Low beam bulbs works with the headlight assembly off the fender and energizing thru a 12 volt battery.
I have the WSM for the mk1 996 but that does not help to solve the problem.
Does anybody kwow the colour code of the wiring between the fuse C4 and the relay for the fuel pump?
