E-gas with better-heel-toe = SprintBooster ???
Here's my scenario:
On the gas hard while approaching a turn.
Off the gas and right-toe-ball goes on the brake.
When enough speed is scrubbed, left foot onto clutch, roll right foot (while still on the brake) to blip throttle, shift gear, off clutch, right foot goes totally on to gas as I enter the turn.
Obviously this lets my car take a set before entering the turn, but I'm constantly battling with timing cause my throttle blips are not consistent.
Problem is the e-gas throttle mapping is sluggish and slightly non-linear (including the slight dead band in top position), causing the RPMs not to get high enough during my blip, or going too high because I have to leave my foot on it so long while I'm doing everything else.
Never had this problem with my cable-cars, and I'm finally done compromising with this car.
What say you? What solution is there to get better blip throttle response while keeping the throttle modulate-able? Is it really the Sprint Booster still?
(BTW, if anyone has a broken Sprint Booster I'd love the chance to take it apart and see what makes it tick. I'm an electrical engineer and as long as it's not epoxy filled to prevent reverse engineering, I'd love to take a stab at building my own. From what I understand of Egas, it can't be very complicated inside, and $329 is waaaaay steep for what may only be a couple op amps and gain networks inside. I know people need to make a living, but come one, some things are priced absurdly, like charging a Porsche owner $350 for an oil change just cause it's a Porsche.
I disabled mine and the throttle became much more responsive - livelier blips and immediate power delivery. The only side effect I have encountered has been the occasional (and embarrassing) stalling in bumper to bumper traffic, as it takes some practice to get used to the more sensitive throttle. This mod is free, takes 5 minutes, and is easily reversible - so try it out.
There was a thread on the pros/cons not too far back:
https://rennlist.com/forums/996-foru...ay-switch.html
Anyone have any thoughts?
And I will totally send you a prototype if I ever get to know what's inside one of the originals! I find that most students have trouble with the heel-n-toe thing because they are not wearing the correct shoes. Street shoes and almost all "gym" shoes have large clunky soles that make it virtually impossible to truly feel the throttle and the brake. This includes all of the sports shoes and all of the so-called "driving" shoes one can buy at silly expense to profile around in (I have tried many of those as well and discarded them all as neither good driving shoes nor good walking shoes). It also includes shoes like Sperry Topsiders of which I am particularly fond for my regular daily shoe.
I wear Simpson high-top racing shoes exclusively when I track and they make ALL the difference. I ended up with the high-tops because they support your ankle nicely when rolling your right foot between more gas or more brake with that foot. It makes double-clutching down a total breeze. When I recommend that specific change to students, they come back later raving about how much better they can control the brakes and the gas because of the real racing shoes. Low top racing shoes do not provide any resistance for the ankle to "lean on". It is similar to the better quality of throttle control you get when your right foot is slightly off the pedal and "leaning on" the center tunnel.
However, real racing shoes have an extremely soft sole, like an indian moccasin. They will NOT be good for daily use - their rubber soles will wear out quckly in daily use (like a real track tire), and are also considered to be "gold chainer" stuff if you wear them at non-track events.
I fully realize you are itching to find an electrical engineering solution to your problem. But one of my favorite quotes is, "If your only tool is a hammer, you will see all of your problems as a nail."
I've got a decent amount of "tools" in my toolbox, but I tend toward using my favorite ones before going out and buying any new ones. Ha!
