99' Tiptronic 996 Error Codes p0410 and p1411
I've seen many threads on these codes, but does anyone know which parts exactly for me to purchase?
I'm guessing the following........
1) Electric Change Over Valve
Change Over Valve Electric/Vacuum Change Over valve
2) Air Pump Control Valve
Cut Off Valve Shut-Off Valve
3) Air Inject Check Valve
Secondary Air Injection Check Valve
4) Vacuum reservoir
Is there anything else I'm missing. While I'm in there, I might as well change everything necessary. Or am I missing something that can easily be checked/fixed without having to replace all of the above? Could it be as simple as a fuse?
4) Vacuum reservoir
