Help! Sway bar end link mount broke. Can I just take it off and drive
Do I have to take off both sides or can I leave one side connected? The alignment shop is 40 miles away, highway.
Obviously, i'm not going to hot dog it because it creates an oversteer situation. But do I have to take off both sides?
I guess I can leave the sway in, right?
You can leave one side connected but remove or tie up the broken link so it does not do any more damage to anything. Most cars will drive fine without any sway bars at all, some don't even have them. You just may experience more body roll when cornering.
You're bound to bang up the sway bar with the control arm, especially since the suspension will now travel a lot more. I'd pull the whole thing out and and take turns reaaally slowly.
when you say whole thing, you mean the driver side endlink as well, correct? I was just thinking to remove the body of the endlink (red part and the end that part that connects to the shock) since it's adjustable.
What do you think? Thanks. At least it's not more serious.
I would disconnect both link... the link that is attached will moved the bar up and down and might rip that tie wrap off on the other side.... isolating the bar movement is key. disconnect the links and hang everything tight.
Edit: just read the last post... you should be good. GL
