Are there any good write-ups on changing the oil cooler /heat exchanger?
try searching for AOS.... but doing it from the top. The AOS is on the other side of the plenum opposite from the oil cooler. Ive removed the plenum to get to the AOS, but the left side, for the cooler you have to remove the right side to get to the cooler. It might be even easier since you don't have the alternator to deal with.
