urgent: CDR 23 antenna?
my 2003 996 is in the shop now getting oil change/maintenence.
I bought the SCOSCHE IPFMRDS Fm modulator. He took out the radio to wire it in, but there was NO ANTENNA! The area where the antenna wire/plug is supposed to go is SEALED off and there's no connector. Basically there's just the wires coming from the car to go to the radio but no antenna is coming from there.
where can he plug in the modulator's antennae?
Super Moderator
You may also need the antenna adapters as well
http://www.crutchfield.com/g_119400/...s.html?tp=2569
you are correct, he said that you need 2 adapters, and they're roughly $25 each. So total for the installation of this with labor and parts is $35 labor + $129 for the scorsche and another $50 for the double adapters.
