Side marker lights install
OK, removed the bumper today and cleaned the rads and fixed the horn (yippee!). Reassembly has gone pretty smooth, with no extra parts. I'm down to the final part; installing the side markers.
The PO installed LEDs, so they are not stock. When I took them off, they came off pretty easily, but the little brass curvy bit was not attached. For the life of me, I cannot figure out how to get that piece back on and get the bugger installed. Any tips/links?
Helps immensely.
I just can't see HOW to get it in there. As you can see in my last pic, there is a metal piece already in there. I guess it "slides" in with that. I tried pushing hard, and harder. I guess I'll push really super hard and see if goes. Unless there is a method I do not know??
Thanks again for your help.
So far this is a fail. All pictures and videos I can find all show the brass piece already in place. I find it odd that neither piece came out with the lights. so they must not have been too tight. Anyway, any last ditch ideas out there. I'd superglue them, but I'm not sure there is enough of the brass part to find purchase within the slot to take hold.
Thanks again, everyone.
the clip doesn't show that it broke off otherwise it would have a flat surface and you would see the broken part still in there. Those aftermarket lights are built too great. Just slide the flat side in the slot with the curved part away from the wires as seen in the pictures. You might want to put some glue on the side to keep it in place.. Which side are you messing with?
