Mishap
Driving the beltway and encountered a piece of wood. Bent left front wheel (inside) and busted boot on axle. Wheel repaired - to some degree, there is still a small amount of vibration. Now for the boot: has anyone had to replace one, and what can I expect to pay? How long should I wait before getting it repaired? The axle is not damaged buy someone told me I would have to replace the axle as well.
Thanks for your help...
Is it a C4 or C4S? If so, you're probably talking about the CV joint boot. Need to replace that ASAP as it keeps dirt and crap out of the CV joint and lubrication in the CV joint. If you run it for very long with a damaged boot, you'll need to replace the CV joint as well - much more $$$
If it's not a 4, then disregard all the above.
Cardigan Millionaire
Depending on how long you have driven it, it might be better to just replace the axle. So much easier to do, takes much less time, and don't have to worry about joint on your current axle being contaminated.
When the CV bearing dust boots on my Boxster were found cracked I didn't worry too much cause with over 200K miles I thought I'd just have the tech install new half shafts with not only new boots but new CV bearings.
But when I took the car in and asked about having new half shafts installed I found the price was $900+ per shaft and then labor on top of this. The tech said he'd remove the old ones, clean the bearings, inspect the bearings and if he spotted any reason to not use the old ones he'd advise me.
But he found nothing scary and after a proper repack and new dust boots the OE half shafts with their original CV bearings are back in service and have racked up several tens of thousands of miles since and I believe can go another 200K miles.
Save some money. Get the car in pronto and have the boots replaced. If the tech insists on replacing the half shafts... well, use your best judgement.
Sincerely,
Macster.
Thanks group for sharing the most helpful information!! It is a 99 C4, 3rd owner, with 78,000 miles. It happened last Friday, drove it once since then. I should have it repaired next week. Dealer wants 80 bucks, but I have another quote for half that amount. Planning on a set of new wheels eventually.
