996 Forum 1999-2005
torque spec needed
Old Apr 25, 2012 | 10:42 AM
tbanasiak's Avatar
tbanasiak
Default torque spec needed
so i noticed a slight seepage of oil at the bottom of the trans bell housing, while under checking things out i also noticed the 10mm 12pt bolt was way loose (clutch was replaced @ year ago at a dealer in cali) anyways can anybody chime in with torque specs for bell housing bolts? Thanks!
01 996 c2 6spd
Old Apr 25, 2012 | 07:17 PM
Byprodriver's Avatar
Byprodriver
10mm bolts are 33 ft./lbs.
12mm bolts are 63 ft./lbs.
If you are talking about the internal triple square bolt do yourself a favor & either buy a Quality short bit to torque it or remove the 10mm X 50mm bolt & replace with conventional bolt.
Old Apr 25, 2012 | 08:39 PM
tbanasiak's Avatar
tbanasiak
all bolts are external, they mount the tranny bell housing to the engine. all are hex head except for 1, the oddball is the 10mm 12point triple square bolt.
