Using different brake pad compounds F/R
I'm thinking of following the advice in this thread and installing Hawk DTC70s in the rears and DTC60s in the fronts for use (only) on the track. The idea is to put the more aggressive (initially) pad in the rear in order to dial out a bit of the factory-set strong front braking bias.
Does anyone think this is a really bad idea?
Im going to use the Pagid yellow/black combo at Sebring and see if I notice a difference. I doubt I will but no reason to think it is a "bad" idea. Ive only used yellows so far.
