996 Forum 1999-2005
Fire Extinguisher
Old Mar 2, 2013 | 02:30 PM
Neb's Avatar
Neb
Originally Posted by 996_North
Carry one, it doesn't mean you have to use it. They are good for breaking glass as well.
Does anyone use this rear seabelt mount ? Does this meet DE metal to metal requirements ?
I have this mount, and yes PCA UCR approves the use of this for DE events.
Old Mar 4, 2013 | 04:03 PM
996pp's Avatar
996pp
Previous owner had this installed in there (hope i never have to use it)
File Type: jpg
Old Mar 4, 2013 | 04:22 PM
pongobaz's Avatar
pongobaz
I installed the rennline mount a few years ago...works great and luckily I've never had to use the extinguisher!
File Type: jpg
File Type: jpg
Old Mar 4, 2013 | 08:26 PM
morganabowen's Avatar
morganabowen
Must be very uncomfortable for your rear seat passengers
Old Mar 5, 2013 | 02:42 PM
JMLavoie's Avatar
JMLavoie
Pongo:
Did you put in dry chemicals or Halotron in your fire extenguisher?
I assume you did buy the FE in Canada. Where can you get it filled if it is Halon?
Thanks in advance as I believe this mod is a very smart/safe thing to do! Merci!
Martin
Old Mar 5, 2013 | 06:21 PM
Livefreeandrive's Avatar
Livefreeandrive
Check out my Fire extinguisher post in the 993 area. I started the seat belt mount craze
Old Mar 5, 2013 | 07:19 PM
Carrera51's Avatar
Carrera51
We carry both Halon and Halotron as well as the sodium bicarbonate based dry chemical hand helds and all three are in stock.
http://www.ogracing.com/halotron-fir...guisher-2-5-lb
http://www.ogracing.com/halon-1211-f...isher-2-5-lb-2
http://www.ogracing.com/sodium-dry-p...guisher-2-5-lb
If you have any questions, we would be happy to assist you. We can be reached at 1-800-934-9112 or via email at info@ogracing.com
Kind regards,
Old Mar 6, 2013 | 09:13 AM
Long Islander's Avatar
Long Islander
Don't worry, with that mounting location, you'll never be able to use it because you won't be able to get to it. It's only useful if you can reach it from the driver's seat.
Old Mar 6, 2013 | 02:44 PM
996pp's Avatar
996pp
Im very quick on my feet
