Need Touch Up Paint in Aerosol (Guards Red)
Rat Balls
Local Dealer says Porsche does not make touch up paint in aerosol only in a brush on. Need a recommendation on a good source online or retail. Thanks.
You might try these guys also. I had good luck with them on spray touch up for my Porsche, Benz and GMC truck. Good luck.
http://www.automotivetouchup.com/
JohnCA58 (05-29-2022)
I was about to order from these guys for my new to me 996 gt3. Was it a perfect match? Did you get the clear coat too? I need to paint right behind the front wheels on the side skirts. All the paint as been sandblasted away. No issue from the side but I know it needs work.
I've tried Paintscratch and Tower as well. Paintscratch is pretty much on pare with Automotivetouchup and I don't think you can go wrong with either.
Thanks for the follow up. I've got a seal gray car but given the location by the ground and behind the tire as long as its their best effort on the color it should be fine.
por944trs (05-28-2022)
I've heard this about Testors red but is there a specific color "name" or is it just Testors "red"? I have some out of the way places I'd like to touch up on my '88 and don't need to go through ordering from paintscratch.
TIA
TIA
There are some great options here .. i just want to paint some plastic nut covers to match my brake calipers ... which i am assuming are guards red ... please correct me if i am wrong ....
