IMS Retrofit, Clutch, and Short Shifter
Hi all, would love experiential input on an estimate I have. Using a independent (albeit a prominent one) here in North Texas. I am having the IMS retrofitted. While they are in, they are going to do the clutch AND I have been wanting a short shifter, so they will do that as well. The IS and clutch combo quoted at $2400 and we estimated around $500 for short shifter install (parts and labor for all). Does $2900 sound reasonable for this amount of work. Are there any other opportunities/risks should anticipate while they are doing this work?
I got a good feeling for this place (RAC Performance) and obviously I want to understand as much going in so to minimize surprises (or hater up-sell). Any insight is appreciated!
When I used to live in that area, I always take my car to RAC and they always do a great job. For the SSK install, I got quote from RAC and Boardwalk Porsche dealer and RAC was cheaper for labor. I ended up doing the install myself with help from this Forum especially Tim (Gota911). Cheers,
I dont think that sounds out of line. He has to make a few $$ too. Is that with a new flywheel?
Other things while you are there?
Rear main seal to the newer style
Pending the year. Updated clutch fork
Air/Oil seperator.. is right there and would be a 10 min job vs 4-6 hours
While the trans is out the 2nd gear kickout prevention mod
Tranny oil change
and if you are doing the clutch.... A flywheel would be the proper way to go
Tranny oil change
Great input here. Thanks all. I will definitely use RAC for the IMS and clutch work. I have some notes captured on flywheel and will inquire as o RMS and AOS remediation. The SSK work sounds temping as DIY. I don't know the first thing about this stuff but am interested with the right coaching. Anyone in DFW interested in coaching? Beers and first test drive after change are in order :-)
Thanks again, all. This is exactly why I joined this forum. Great support!
Randy, your IMS may have been one of the four that they said they had on the shelf that had been retrofitted. I will have them set mine aside to see what condition it is. If you're in the area, let's meet for coffee (or a beer) sometime.
I agree...while I want peace of mind, I do not want to be throwing out suggestions for these guys. The AOS and RMS makes total since. I will get clarification on to what extent the clutch work is being done. I called the clutch out initially because the clutch does not engage until the pedal is almost completely let out. Definitely too loose in my opinion. Not sure what that translates into necessarily from a clutch remediation perspective, just that the pedal was the driver for the work.
Team, I am definitely going to go the DIY on the SSK. Two questions:
1. B&M or EVO? Or other? Leaning toward B&M based on others posts across the forum.
2. Do I want/need to do the linkage? With linkage, is it still a DIY?
and whenever you do a clutch you should have the FW turned. but a duel mass can not be turned.
A proper job would be with a new FW
