ABS motor keeps running ??
Help!!! I have a 05 GT3 and I was going to take it out this past week and the battery was dead, had to jump with the fuse panel to get trunk open, I replaced the battery with a new OPTIMA RED TOP and now the motor on the back of the junction block with all the brake line under the brake fluid reservoir keeps running as soon as I connect the battery.
When I start the car the ABS fail light and brake light stay on, and I get a warning from the info center that the ABS has a malfunction.
I tried to start the car with a battery booster, 50 amp Before I knew the battery was junk. The outlet that I had the trickle charger plugged into became unplugged THAT IS WHY THE BATTER DIED.
I drove the car a few miles and the anti locks don’t work but brakes are OK..
This car is has never seen rain or snow, and is stored in a heated garage..the car has only 5225 mile on it.
HELP!!!!! ANY IDEAS??? Is there a relay for the ABS motor that may have become damaged during the battery issue????
Try taking it out again up to about 50mph on a flat straight surface.. check your mirror and slam the brakes on as hard as you can. See does that get the ABS working again. Anything is worth a try.
