nokia amp wiring.....help!
So I am replacing the nokia amp with a rockford one. I was able to read the porsche diagram and figure out the speaker out...but I dont know what the colors are going in (signal) any helop would be great.
Mitch
Mitch
Here you go
http://www.renntech.org/forums/topic...x-40-watt-oem/
I re did my whole system and wired in the new Rockford front amp using this. All you need to use is the wires for the speakers and tuck the rest of them under the trunk carpet. Run the RCA's to your me head unit, a fused hot to the battery, a ground to the steel of the area behind the amp location and an ignition sense back to the head unit. It took me about an hour.
