Quote:
Is the spring in the gearbox?
I would assume so, but the above is the extent of my actual knowledge on the topic. I only know that much because I swapped my shifter out myself.Originally Posted by jasper
That's what I was struggling to remember. How does the shifter centre to the 3/4 plane then?Is the spring in the gearbox?
afraid so,,Originally Posted by jasper
Quote:
that tool only works with the stock shifter,,Originally Posted by himself
As I noted above, there is a centering tool. I think the green one is the one you need.
i checked the new cable i got from Porsche,, the part number is 99642404109,,
the old one was 99642404112 which was updated to 99642404114,,
the cable ends at the rear of 99642404109 have plastic housings while the old one had metal housings,,
could be the problem?
