Engine noise when warm, fine when cold!
In cases where there is a noise from the engine or possibly the transmission/drive train that I have not 100% identified the source I prefer to err on the side of caution and have the car flat bedded to the dealer to avoid the risk of more damage, more collateral damage, should the noise be a pending more serious problem.
In the case of your car that the noise -- I'm not sure what the noise is? Ticking? Knocking? Something else? (And this is not a hint that you need to post an audio clip. Until you know the source of the noise and what it likely means the less running of the engine you do the better.) -- goes away when the Tip is put into gear could arise from the Tip.
I'm not all that familiar with Tip equipped cars and their noises. But in the past I have experienced other automatic equipped vehicles and in some cases the noise was from heat shielding or some part of the exhaust system or even the body that was vibrating at idle but when the automatic was put into drive and the idle speed decreased and the engine changed its position due to the torque presented by having to spin the torque converter the noise stopped. IOWs, the source of the noise was pretty benign.
But in other cases -- not to scare you just to be thorough -- the noise proved to be from a bad automatic.
It can be from other things as well, something serious and in need of attention but not necessarily as serious as a noisy transmission.
Get the car to a shop for a professional's diagnosis.
Best of luck.
