996 Forum 1999-2005
Low temp thermostat - which one
Old 01-19-2012 | 06:53 AM
318touring's Avatar
318touring
Default Low temp thermostat - which one
This thread is NOT for debating the benefits of low temperature thermostat.
What I'm asking is, from the list of thermostats in Pelican parts page, which one is the 'correct' low temp thermostat.
As can be seen there are at least 3 brands (Wahler, LNE and MotoRad), and they vary in prices. If they are fundamentally the same, why would I get the most expensive one?
The Wahler one has this "Water Thermostat, Low Temperature (begins opening at 160 deg F) with Cover and Gasket, 996 Carrera 2/4 (1999-04)
Brand: Wahler"
Old 11-06-2013 | 03:19 PM
NJS_04_996's Avatar
NJS_04_996
~BUMP~
I was in the process of ordering a water pump and thermostat in the next day or two, and was looking at a MotoRad thermostat only vs the Wahler kit, which included the housing and gasket (seems like the latter is a idea)
Old 11-06-2013 | 04:31 PM
rglbegl's Avatar
rglbegl
Instead of starting a new thread, I am going to ask here;
My local dealership said if I change my thermostat that I need a full ECU reflash.
Has anyone heard that before?
Old 11-06-2013 | 04:46 PM
soverystout's Avatar
soverystout
Uh, no. Remember that these lower temp thermostats START to open at earlier temps which can help to eliminate hot spots in an otherwise perfectly functioning coolant system.
They still get nice and hot, they still produce great cabin heat, and the engine still takes a long time to cool down after a hard run. Gas mileage is not impacted and LN has determined that very slight (did I say very slight?) performance gains are a potential outcome.
Been running the LN low temp stat for 2+ years in northern Delaware where we get every kind of weather an temperature variation.
Old 11-06-2013 | 04:47 PM
BAD.TAG's Avatar
BAD.TAG
Originally Posted by NJS_04_996
~BUMP~
I have the Wahler that included the housing as well. Wahler is OEM and I have had no problems thus far
Old 11-06-2013 | 05:07 PM
alpine003's Avatar
alpine003
Time to find a new dealership. Next time ask them if your ECU also needs to be reflashed if you refill your blinker fluid.
Old 11-06-2013 | 05:20 PM
Ahsai's Avatar
Ahsai
+1
Old 11-06-2013 | 06:27 PM
Hurdigurdiman's Avatar
Hurdigurdiman
hahaha yeh 'or the oil in the windshield wipers" hahaha.
Old 11-06-2013 | 08:10 PM
rglbegl's Avatar
rglbegl
This is what I figured. Read a few threads on here and didn't see anything about it. I think it is because I am going in with my own water pump and thermo. So if they can't make money on parts, they will try to sell me a $400 ECU reflash. (He said it was to make the fans come on sooner, etc etc)
Thank you for the responses
Old 11-07-2013 | 10:18 AM
perryinva's Avatar
perryinva
+2
Old 11-07-2013 | 12:19 PM
BAD.TAG's Avatar
BAD.TAG
... they will try to sell me a $400 ECU reflash. (He said it was to make the fans come on sooner, etc etc)
Are the fans activation even controlled by the ECU or an actual thermostat switch ?
Old 11-07-2013 | 01:49 PM
perryinva's Avatar
perryinva
They are controlled by the ECU (you can switch them on via Durametric or Enginuity) and they use actual coolant temp input, so I see no reason at all to make them switch on sooner with a LT T-stat. Makes no sense. The coolant temp, is the coolant temp, regardless. During SOT, an LT T-stat is just more open than the stock one. At 10-20 degrees above SOT, they are both wide open, and there is no difference.
Old 11-08-2013 | 07:27 AM
kromdom's Avatar
kromdom
when I had my pump/tank/cap/t-stat done, indy said stay with OEM.
Old 11-09-2013 | 01:12 PM
Viper6's Avatar
Viper6
i ordered the $40 Motorad from Pelican... it is made in Germany (US Motorad did not even know it was made at all since not avaio from them in USA). I have not put it in yet so I am watching these threads carefully... who makes the LN T-stat?
Old 11-11-2013 | 11:17 PM
fpb111's Avatar
fpb111
It looks like Porsche went to a lower temp thermostat in the 997.
Quick Reply: Low temp thermostat - which one
