996 Forum 1999-2005
TIRE ADVICE NEEDED FOR AN 03-C4S
Old 01-12-2012, 05:22 PM
Coop
Coop's Avatar
Talking TIRE ADVICE NEEDED FOR AN 03-C4S
Hey guys,
Anyone running a 285-30-18 from the factory 295-30-18?
Please chime in!
Old 01-12-2012, 05:43 PM
Hardback
Hardback's Avatar
No, why do you ask? Ive gone to 315s on the stock wheel with no issue. I doubt 285 would be a problem but you should look at the tire specs of whatever tire you plan to mount and read the recommended wheel widths for that specific tire.
Old 01-12-2012, 05:55 PM
Coop
Coop's Avatar
My friend is looking for other tire options. Ones that are cost effective...
Old 01-12-2012, 06:02 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,473 Likes on 924 Posts
Winter or summer tires? I think it would be better to buy the proper size, but consider a brand or model with a lower price like Sumitomo HTR-ZIII. It's a good tire for the money in my experience.
Old 01-12-2012, 08:35 PM
vange_c4s
vange_c4s's Avatar
dennis,
i have not tried the sumitomo tires. i have ps2 now. how do the sumitomos compare to the ps2?
Old 01-12-2012, 10:25 PM
dotframe
dotframe's Avatar
I recently put on the sumis (htr zIII) in 295/30/18 and 225/40/18 and I think for the money they are hard to beat! The previous tires were PS1s but they were old and bald so I don't think any comparison would be fair.
The Sumi 295s were only $223 each.
Just make sure you get the overall diameter very close to the front or it'll wreak havoc on the AWD.
Old 01-13-2012, 12:43 AM
2K7TTMIA
2K7TTMIA's Avatar
Hankook V12 Evo's also are a good buy and hold up quite well for DD, southern tire; don't know how they hold up in below freezing climates.
FWIW, I may try the Sumi HTRZIII, but that should be the bottom rung as far as cost effectiveness.
To the OP, unless your friend has a beater Pcar and is looking for least expensive, better to look for good used tires ( Michelin, Conti's, Pirelli's) than try subpar rated tires and suffer a failure if he takes the car above 80-90-100+ mph.
Is your friend's car lowered? does he need a thinner sidewall for clearance issues? According
to 1010 tires.com:
295 30 18 section width: 11.61in overall diam 24.96
285 30 18 section width: 11.22in overall diam 24.73
so your friend is getting a narrower tire (.39in) and a shorter tire (.23in); YMMV.
Old 01-13-2012, 01:46 AM
rxbike
8th Gear
rxbike's Avatar
2nd for the Hankook Ventus Evo V12. I have these on my 996 and my S4 . Very predictable handling and nice and sticky. So so for wet but this is a high performance summer tire.
Old 01-13-2012, 08:00 AM
Coop
Coop's Avatar
Ok guys! Thank you for your help. Love this place!
Old 01-13-2012, 08:54 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Originally Posted by vange_c4s
dennis,
I haven't tried the PS2 before, so I can't give you a direct comparison. I always had Pirelli P-Zero Rosso tires before I bought a set of Sumis. The HTR-ZIII is pretty good for the money. My set lasted for roughly 15K miles, which is better than I used to get out of the Pirellis. I've still got some life left in the fronts, but not too much.
I think the Sumis are fine for street driving. They don't handle quite as well as the Pirellis did, but they are pretty close on the street. They did get a little loud towards the end of their life, but the Pirellis did too.
I need to buy a new set of summer tires before the warm weather arrives. I'm thinking of going to Michelin Super Sports if I can find them in the proper size. If not, I'm not yet sure what I'll get.
Old 01-13-2012, 10:27 AM
Hardback
Hardback's Avatar
I know a lot of guys here like the sumitomos so I thought I would give them a try. They are excellent in the wet which is important in S. Florida but they are very stiff in my opinion. The roads in my area are horrendous and these tires need to be bled down. My tire $ usually goes toward R comps so I dont mind using a bargain tire. But, like Dennis said if michelin would make the super sports in 295 I would buy those exclusively.
Old 01-13-2012, 01:23 PM
Zapna
Zapna's Avatar
Before changing tire sizes, you might want to look at the effect on the tire size. You can do so at: http://www.miata.net/garage/tirecalc.html or http://www.1010tires.com/TireSizeCal...?action=submit
As 2K3TTMIA mentioned, you want to keep as close to the stock diameter as possible, or increase/decrease front/rear proportionally.
Good luck!
Old 01-13-2012, 06:32 PM
Byprodriver
Byprodriver's Avatar
285/35 should be a good compromise height wise & should be cheaper since it's a higher profile & not a "Porsche size"
Old 01-13-2012, 06:40 PM
SSST
SSST's Avatar
One thing to be careful of when changing sizes on the C4S is the difference between the F/R tire diameter. Get it too far off and you can create all kinds of problems. Don't want to mess up the front diff.
Old 01-13-2012, 08:34 PM
vange_c4s
vange_c4s's Avatar
thank you for your experience. ps2 are very nice and in correct size and n rating if you cant find the super sports.
Quick Reply: TIRE ADVICE NEEDED FOR AN 03-C4S
