996 Forum 1999-2005
3.4 vs 3.6 motors?
Old 12-21-2011, 02:02 AM
aaronazevedo
aaronazevedo's Avatar
Default 3.4 vs 3.6 motors?
So my search goes on. I had a car sold out from under me today, even when I had a deposit down and a ppi scheduled. Really? So disappointed in people!
Moving on. I'm finding these cars are kind of a dime a dozen, so it's going to be a fun and longer search to find the 'special' car. Ha! So special is pretty subjective.
I do want to hear all of your opinions on the '01 cars with a 3.4 liter motor vs the '02 cars with a 3.6 liter motor. Are their reliability differences? Drivability differences? Longevity differences?
Secondary, are their any other dramatic differences between '01 and '02 cars?
Thanks in advance.
AA
Old 12-21-2011, 04:59 AM
oojkoo
oojkoo's Avatar
Thats a great question. I've always been quite curious myself.
Old 12-21-2011, 11:57 AM
logray
logray's Avatar
3.6L is worth a few more HP 315 vs 296 and torque 273 vs 258. Also has a beefier crankshaft with a longer stroke. Better variable cam timing mechanisms.
3.4L has more timing chains and some have a stronger IMS bearing than the 3.6L.
Go for the 2002+ if you can afford it.
Old 12-21-2011, 02:03 PM
dennis hiip
dennis hiip's Avatar
Heads were redesigned in 2002. Possibly less likely to crack.
Old 12-21-2011, 02:05 PM
KrazyK
KrazyK's Avatar
It seems the 3.4L rarely has an IMS failure compared to the early 3.6L. The last 3.4's are surely better than the early 3.6's. Your right, they are a "dime a dozen" and there's a good reason. Word is finally spreading about the reliability issues of the 996. Ask any Porsche dealers about his used 996's on the lot. Many go straight to the auction.
Old 12-21-2011, 07:36 PM
robo_porsche
robo_porsche's Avatar
I have tried both the 3.4 engine (with and without the powerkit) and the 3.6 and I think that the 3.6 engine runs a lot better. The 3.4 is not bad, but the 3.6 feels a lot better. I chose the 3.6 myself and I would recommend that if you can afford it. It is really worth the price difference.
An even better option is to try out cars with the different engines and then judge for yourself.
I really think that the IMS problem (I guess this is the reliability problem refered to above) is greatly exaggerated. It is after all not that many engines that have failed (there are no real statistics available to be honest). There is also a solution to this problem delivered by LN engineering at a reasonable cost (about 600 $ + work equivalent to switching the clutch).
Robert
Old 12-21-2011, 08:15 PM
TRT41
TRT41's Avatar
Porsche dealer with a 996, non turbo? I don't recall seeing any for several years at the Dallas dealers. They are not the correct pricing point, non Porsche dealer totally different market.
Old 12-21-2011, 10:07 PM
logray
logray's Avatar
I'll quote someone who said this previously. "KrazyK, you crazy."
Old 12-23-2011, 01:18 AM
Tbred911
Tbred911's Avatar
actually the new head design is inferior to the old one... I remember reading one of Jake Raby's post concerning the flow of coolant that created hot spots etc...
Also from my browsing the 2002-2004 motors have more IMS failures than the later 3.4 motors... this is true!
as for the torque difference... the 3.6 is more flexible and has more torque at lower rpm but once you are above 4,000 there is no advantage....
the 3.4 also responds better to a GIAC chip flash vs the 3.6 where you can't squeeze any more out of it...
if you can find a 996 with a re-man 3.4 I would go for it....
whatever motor you decide on make sure you do a compression and leak down test and you can verify the mileage through service records.
Old 12-23-2011, 03:48 AM
DreamCarrera
DreamCarrera's Avatar
+1,000,000
Old 12-23-2011, 05:32 PM
jasper
jasper's Avatar
I focused my search (twice now) on the 3.6 litre cars. I've had two now and I plain love(d) them both.
The variocam plus gives a very noticeable performance benefit below 4000 rpm and the bugs that plagued the 34 litre motors were sorted (first I've ever heard that 3.6 motors are more prone to failed IMS bearings than any 3.4). That said, my car had a new motor installed in 2005, so probably a M97 which has a totaly different IMS bearing than any of the M96 came with.
Besides the mechanical advantage, the interior of the MkII cars were improved with a glovebox, cupholders, standard alcantara headliner, and overall better materials.
The redesigned headlights are subjective, but the bumpers reshaping made for better cooling and more downforce.
Lastly, the MkII cars were stiffer.
Buy the best you can afford, but there's no denying the MkII cars were an improvement of the MkI cars.
Old 12-23-2011, 08:42 PM
Tbred911
Tbred911's Avatar
I heard that stat from a porsche service advisor! the 3.6 cars also have more AOS issues than the 3.4's...
probably not... the new bearing design was introduced in the later half of 2006 so remans made in 2006 had the update... not before
unless you get full leather... yes... more creature comforts and much much better stereo in the 3.6 !!
better cooling... absolutely... if you track the 3.4 you will need to install a 3rd radiator in front...
more downforce...?? you will probably throw away the stock suspension in favor of the factory ROW 030 and that puts "rake" from rear to front that generates more downforce...
Old 12-23-2011, 09:06 PM
PFAR
PFAR's Avatar
I have an MK1 (2001) C2 I purchased a few months ago. When I was looking to buy, I wanted to get the bump in hp from 300hp (MK1, 00 & 01) to 315 hp (MK2). Also, I preferred the more aggressive looks of the MK2 lights.
After test driving a number of both variants, I found that there was very little between the two ... but I could definitely feel more of a 'kick' at lower rpms in the MK2. But quite honestly, I didnt see much difference in performance between the two ... and since '01 and '02 were nearly at the same price point, I decided to try and find the car that had been serviced best. I ended up purchasing a well-optioned, 1-owner, low mileage 996 C2; every single service record from day 1 and all servicing at the local Porsche dealership. Couldnt be happier.
That would be my advise to you: get the better serviced car between the two. And please dont decide to shell out extra $$$ just to get the next styling in headlights .... unless that makes you happy, in which case go for it!
Old 12-23-2011, 10:10 PM
Tbred911
Tbred911's Avatar
FWIW I prefer the look of the MK I lights as they are the exact shape come from porsche's race car... they make the car look sleeker... IMHO.
as for the lower torque.. yes the 3.6 definitely has more engine flexibility below 3500 rpm and you can even cruise around in a higher gear at lower rpm... but if you are tracking you are never below 4000 rpm and this is where the 3.4 really shines!!
I have found through experience the MKII blows through more catalytic converters than the MKI
the poster above did it right... full service records - *verifiable* and well maintained car is what you go for .. MKI or MKII
Old 12-26-2011, 05:39 PM
oojkoo
oojkoo's Avatar
Thanks for all the input guys. I think i made a great decision
Quick Reply: 3.4 vs 3.6 motors?
