Fuel Injection Test Port
Does anyone know the thread size and pitch for the schrader type fitting on the fuel rail ?I need to test the fuel pressure and need to buy an adapter for my tester .Thank you
Dave
Dave
From other sources such as the following it is M14 x 1.5.
http://www.renntech.org/forums/topic...-fuel-pressure
And you can buy the adapter from Porsche p/n 00072195590.
Gasp. $140 discounted.
Here's a tip I found about using the harbor freight AC kit...
"HF AC service kit (item# 92649). The low pressure side has the correct pressure range and the fitting was a lot deeper and caught the threads and made a good seal."
from http://www.renntech.org/forums/topic...ost__p__204298
