GT3 Sway bar & Adjustable drop link installation DIY - help needed
Now that you mention it, yeah, I've seen that too. You probably want to adjust it while the wheels are straight. You should be able to feel the resistance in the turnbuckle as you reach neutral and over/under-adjust it; the middle of the neutral spot is where you want it to be.
