My car went to Porsche for a new starter and when I got it back I noticed that the front trunk light is not coming on. The bulb is okay, no 12V at the light terminals. Where is the switch located that activates the front trunk light?
The switch is part of the latch assembly. I would guess the service folks may have taken the fuse out of the block to keep the battery from draining when servicing your car. Check the fuse block to see if the fuse is missing, which is probably why you don't see the 12V at the bulb contacts??
