996 Forum 1999-2005
HELP IM LOCKED OUT
Old 11-02-2011 | 12:32 AM
996 FAN's Avatar
996 FAN
Unhappy HELP IM LOCKED OUT
Just got back in town from one week vacation, car ('99 996 Carrera 4) was parked and locked in garage, now she wont unlock with fob key and the door lock key wont manually open her either. It was recommended that I have her towed to dealer to unlock. Is that best remedy?? Help!
Old 11-02-2011 | 12:35 AM
ivangene's Avatar
ivangene
Parts Specialist
battery dead???
Old 11-02-2011 | 12:37 AM
nick49's Avatar
nick49
I'd try using the emergency wire cable to open the frunk, charge the battery on the car. See if that helps. The locks are power operated and a low battery may prevent them form unlocking. Use a battery if the car's not driven daily. These batteries discharge very fast.
Old 11-02-2011 | 12:45 AM
ivangene's Avatar
ivangene
Parts Specialist
car goes into sleep mode doesnt it???
someone read the method to UNSLEEP the car - I forgot how....
Old 11-02-2011 | 01:06 AM
The DareDevil's Avatar
The DareDevil
The key should unlock the car from the driver's door.
You can't turn the key once it's inserted?
Old 11-02-2011 | 01:21 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
If you unlock it with the key and then start it up, it comes out of sleep mode. It sounds like that won't work here...
Old 11-02-2011 | 01:36 AM
jdog's Avatar
jdog
Poke her in the rear she'll wake up!! Oh wait. I would call AAA and see if they can help. It seems odd that even if it was in "sleep" mode there should be a way to get it unlocked without the aid of battery power.
Old 11-02-2011 | 02:06 AM
fpb111's Avatar
fpb111
Manually unlocking it should wake it up unless the battery is dead.
Do the early 996 have the plus battery jumper contact in the engine compartment?
If so it may be easier to open the engine compartment than to go fishing for the frunk release. It is between the left rear light assy and the bumper.
If you use a soft wedge to open the seam a little you can see it coiled there and reach it with something thin; wire, steel pocket scale, small penknife...
Then jump it using the plus lug and the airfilter housing bolt to hook up the jumpers.
Old 11-02-2011 | 02:37 AM
Quix's Avatar
Quix
Lots of threads but not much in the way of real info. Try this one:
http://www.renntech.org/forums/topic...ncy+front+hood
Good luck, keep us posted.
q
Old 11-02-2011 | 05:51 AM
Pac996's Avatar
Pac996
He says the key isn't unlocking the door besides the fob not working. If it's a model the needs the power to work the lock using the key then charging the battery by using the emergency pull cable to open the hood is the best bet. I know my door doesn't need power to unlock..........maybe
Old 11-02-2011 | 10:36 AM
C4CRNA's Avatar
C4CRNA
Lot of door locks don't work manually (they're never used) so nobody knows theirs doesn't work.
Everybody uses remotes and when car battery is dead remote won't open the door.
Getting power to the car via either trunk will not get car out of sleep mode,now it gets complicated.
Old 11-02-2011 | 10:41 AM
cuttinsod's Avatar
cuttinsod
my key only works if you insert it the right way...rotate the key 180 deg. and try again...
Old 11-02-2011 | 11:33 AM
fpb111's Avatar
fpb111
How do you get the big black end to fit in the lock??
Old 11-02-2011 | 11:41 AM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
I use a rubber mallet .
Old 11-02-2011 | 11:57 AM
ivangene's Avatar
ivangene
Parts Specialist
Quick Reply: HELP IM LOCKED OUT
