Tire pressures.......18' wheels
Full car with 4 passengers? A rare occasion but that would still be only an extra 100 lbs. in a 996: two kids @ 40lbs each and a 20 lb suitcase in the frunk! Not enough to change tire pressures for.
I'd also tend to stick with factory specs ... but I did wonder why on other cars they recommend higher pressure when running 100MPH+ (Mercedes for example) - so does that mean Porsche only specs for high speed - and does not have a low speed spec (for better ride) ? At a AutoX I went to , many owners ran their tires at a slightly lower spec for better grip (but this is also low speed). If you go too low you run the danger of cracking the rim - like the picture above. I dropped my rears to 42, and have been running like that for a while - with no apparent problems (I run 265/35-18 on the rear - which is the a/s spec) - but I think Thundertub gives the best advice here ....
Ok, thanks for all the replies.........however.......it just seems odd to me that they went from 36 with the 17" wheel to 44 on an inch larger wheel. Traditionally as tires get larger/fatter the pressure goes down somewhat........as in a bicycle tire uses something like 65psi and most cars use something around 32 - 36 psi. Now we jump one inch larger and need another 8psi! Just seems bloody odd to me is all. Are they using the pressure off the GT?? for the average 996 with fat wheels? If so, perhaps it's not required.
Now, I'm not about to do anything stupid like run them too low but just thought I'd ask the collective wisdom of the forum y'alls opinion..........and yes, I get it that the manufacturer spends lots of time and $$ working these things out.....but???
Porsche spent a LOT of time, money, testing, and energy doing actual engineering studies to come up with those numbers of 36/44 for the 18" rims. The numbers were achieved by actually testing to see which tire pressures produced the best COMPROMISE between handling, comfort, tread wear, and safety (and a dozen other factors). If you are a tire engineer and know better, then pick whatever you like. I'm not an engineer, I haven't recently slept at a Holiday Inn Express, and I don't believe that the tire pressures recommended by the factory are part of any subplot between Porsche and the tire manufactures.
Honestly, I'm always amazed at people complaining about firm ride or tire noise. You do realize you're driving a Porsche, not a Cadillac, right? Of course, if you drive like a trophy wife (if you're complaining about ride comfort, you do, admit it!!), then you probably want to stick with Porsche's recommended pressures.
