996 Forum 1999-2005
Installed 2010 GT3 shifter yesterday
Old 10-01-2011 | 12:38 PM
MiamiC70's Avatar
MiamiC70
Default Installed 2010 GT3 shifter yesterday
HUGE difference and I am loving it no more row, row, row your boat shifting.
It is very notchy and shifts are precise and solid now feels like bolt action rifle.
If you are on the fence or have thought of doing it all I can say is DO IT!
I also, took the oppertunity to do ashtry delete with a body color painted ashtray delete to match my painted console (thanks go out to Eric @ bumperplugs.com)
Old 10-01-2011 | 01:02 PM
francars's Avatar
francars
Cool stuff. I actually have been looking into the 997 shifter
Where did you get the shifter from?
Old 10-01-2011 | 01:03 PM
Abby Normal's Avatar
Abby Normal
In Your Face, Ace
Any special instructions for the install?
Old 10-01-2011 | 01:13 PM
Optical TDI's Avatar
Optical TDI
I did the standard 997 shifter which made a big difference over the 996. The 997 stock one tightened things up and shortened shifts a little. Bought one on ebay for about $80.
Old 10-01-2011 | 03:10 PM
francars's Avatar
francars
I think SunCoast sells them for $199.
I hope in the next few months I will do this mod. I had a Schnell short shifter on my Boxster and was not bad at all. It was only hard to engage when cold. Is this the same case on these shifters?
Old 10-02-2011 | 09:32 AM
MiamiC70's Avatar
MiamiC70
I got mine from Suncoast as well and I had my local indy install it. Cost me about $100 to install.
Old 10-02-2011 | 11:49 AM
SSST's Avatar
SSST
There is a difference between the 997 SSK and the 997 Gt3 shifters. One is about $200 and the other about $450. Both are a significant improvement over the 996 shifter. The 997 shift kit shortens throws about 20% and the Gt3 about 35%.
Old 10-02-2011 | 10:03 PM
MiamiC70's Avatar
MiamiC70
Under $400 @ Suncoast Parts.
The GT3 one has metal bushings vs. plastic in 996/997 standard shifter.
Throw is about 20% - 25% shorter and feels much notchier and smoother running through the gears.
Old 10-03-2011 | 01:06 AM
Skotch13's Avatar
Skotch13
I installed my 997 shifter this weekend. Pretty easy and much improved shifting from the old 996 shifter.
Old 10-03-2011 | 08:26 AM
Millemiglia's Avatar
Millemiglia
These are the instruction for installing B&M Short Shifter but it's pretty similar...
http://www.bmracing.com/bmracing/ins...ruction/67.pdf
Quick Reply: Installed 2010 GT3 shifter yesterday
