Any easy way to disable 996 alarm without having issues?
Car seems to want to go off at around 2AM in the morning. I know there is an issue because the car honks when I lock it...indication of a trigger that has failed in the hood, trunk, or center console. How can I disable the alarm and keep the car locked until I get it scanned for what trigger has failed? Yes, I have an aftermarket stereo...about 6 months ago was installed, the alarm problem started last month so do not think that is what is setting it off. I have searched the forum and just seen you need to get it scanned by Porsche to see what code is pulled up from the scanner to pinpoint the faulty trigger. Looking for advice. Car is unlocked in the garage but need to lock it at work.
chin996 (04-09-2022)
Also, am looking at getting an aftermarket alarm if this thing costs too much to fix the OEM one at the dealer. Anyone with aftermarket alarms have any input? Might be cheaper for me to just get a Clifford or Alpine with more functions than my 2000 OEM alarm than to waste the money at the dealer fixing this one. Suggestions and input are appreciated.
When you press the FOB to lock the car does it beep once? If so then you have an open door, trunk, frunk, center console, or radio sensor fault. If it double beeps then you have a motion sensor fault. It does not beep then try press the key fob twice to get a double beep. That will turn off the interior alarm. Ses if that helps.
I would still check the aftermarket radio install. There is a wire that connects to the chassis I believe that needs to be taped. I have an aftermarket Alpine installed in mine and I get the single beep (indicating no radio). My alarm would go off by itself randomly, but hasn't done it for about a year now.
Horn beeps once, I would say 70% of the time. I know that is telling me there is an issue with one of the triggers. Right now I leave it unlocked in my garage. Still bugs me as I do not want the battery to die if the alarm goes off at work. I know it will cycle through 5 rotations and then stop. Also, had the aftermarket Kenwood installed for almost a year. Never had an issue till now, that is why I think it is a trigger problem.
Isn't it lock twice quick disables the alarm?
If you have a center console glove box it is also one of the alarm points so make sure it snapped down tight. The engine lid can sure look closed but just resting as heavy as it is without being latched. Another thing is the IR sensors mounted on the dash could be detecting something like a cat walking on the windshield if you have one of those rodents I mean cute kittys.
You need to look around the radio area for a loose wire. I would bet the radio wire has come dislodge from where the installer tucked it away. You should be able to remove the side panels and find it.
Until you find the issue, lock the car then unlock the car and the car will automatically lock itself after 30sec or so as long as you do not open the door...
that way you can have the car locked at work without the alarm going off.. I have to do the same thing as mine goes off every time the interior heats up... and still does after replacing the interior temp switches. The dealer has about given up and the warranty expires in about 1.5k miles!
Is something different on cabs or '02s?
Mine has always beeped once, for all of the 3 yrs I have had it!
THANK YOU SO MUCH!!!! That was just the info I was looking for until I can get it checked out eventually. You are right, works just like you said. Appreciate it. At least now I don't have to worry about the car alarm going off in the parking garage at work and draining the battery.
Post back if you find the issue, I will be doing all of the work on mine here pretty quick and am interested in getting it resolved!
So if your horn beebs once when locking your car it is telling you that something is not working!?! I thought the single beep just told you the car alarm was set. when mine had a door/window issue it would beep twice and the red lock light on the dash would stay on.
