Spent a couple months looking for my first Porsche and finally picked it one up over the weekend (2002 Cab C2). Purchased in LA I immediately drove it home to Seattle - talk about a fun drive!
This leads me to my first 'what the heck is that noise' problem. Driving home I noticed a slight whine coming from the rear half of the car. Driving next to a wall on the passenger side I can clearly hear it (although very very soft and only with the window or roof down). Driving next to a wall on the drivers side, I can't hear a thing!
Ok - that makes me think I have a bad wheel bearing, right? I jacked up my right rear tire and checked for play, pushing and pulling the wheel. Absolutely none. I know this doesn't necessarily rule it out - but it doesn't help my case.
I've rear that the pinion bearings can go bad and cause a similar sound as well, but why only on the passenger side?
A little more info: The sound is directly connected to vehicle speed. Clutch in or clutch out makes no difference. Neither does engine rpm's. Neither does the gear I'm in, even neutral. The sound itself sounds almost identical to my truck in reverse - a whine towards the higher pitch side. Finally, it made the exact same noise at the beginning and end of my drive.
So, I've got these on my list of 'what could it be'. I'm new to this transmission, so I don't know all of the details.
Wheel bearing
Pinion bearing
Fluid running low?
Differential noise? - Hard to tell given it's all one unit
What do people think? What kind of tests can I run to get more info? I'm changing the gearbox oil as soon as I get some in the mail. Thanks!
if bearing is bad on one side you might be able to notice temp difference around the wheel ...but I would not drive the car in that condition. How much brake pad is left on the rears (rotor could be slightly warped ?) ? Did you have Pre Purchase Inspection done by Porsche specialist ? Either way, I'd go to a good indie in Seattle (there are a couple recommended on this board) and for $100-$200 get the car checked out for piece of mind. Could be something simple to fix - or something more serious where preventative now is better than huge bill later.
Some might suggest that you are hearing noises that only a new(to you) Porsche makes, kind of like the smells it makes as well.I hope that's all it is, but it's hard to enjoy your new car when you have these distractions. GL
As another poster mentioned, this sound could be tire related. Our tires get louder as they wear. I had a similar problem, replaced the tires and the noise went away.
Thanks for the input guys. I agree - this is something I'd like to fix before I drive it too much.
I never considered tire pressure, but before I bought the car the dealer put brand new Pirelli tires on. Wouldn't surprise me if the pressure isn't correct.
The brakes have plenty of life in the pads - and I've felt warped rotors before on different cars. I don't think brakes are causing this noise - although I do plan an extensive brake system upgrade soon.
There's no temperature difference (even after doing 300-400 miles between fuel fill ups on the highway) between either side of the car. The whole area was actually cooler than I expected (good ventilation). That's another knock against the wheel bearing.
My plan for the holiday weekend is to put the car up on jacks and to start manually moving stuff in the driveline. Hopefully I'll be able to pinpoint it then. Luckily it's overcast in Seattle this week so the pcar has been living in the garage while I drive my truck to work.
if tires are new you could have tire issue (out of round) not unheard of - especially with Pirellis - - you might want to get balance checked ($10 at Wheelworks) - also did dealer do alignment ? Maybe get that checked (normally free to check) at a good shop. Make sure tire guy has Porsche experience .....
If tire is under warranty they should be able to replace for free if there is a prolbem ...
While I have 1999, my serpentine belt / pulleys whine a fair amount, especially accelerating. It might be that noise that you are hearing, although that does not account for hearing only on one side....
tire noise and.. you worry too much. Stop looking for something to be wrong. You sound like my x wife..
Thats a joke in case you didnt get that son. A joke.. you know one of those things that are to make ya laugh.. are you listening to me boy? Pay attention when Im talkin to you. - Foghorn Leghorn.. mid 70's
The smell isn't cosmoline. Those of us with reman engines installed get the smell also and we don't have cosmoline. The smell is your soft, very expensive rear tires evaporating due to you running the sh*t out of them next to your very hot mufflers. Nothing to worry about, just keep buying a new set of rears every year and you'll be fine.
The noise on the other hand...it may be nothing unusual. The flat six has a bit of a characteristic whining noise buried in with all the other noises. Feature not a bug. Take a ride in another 996 along the same route and compare.
In my case though...on the first 996 I owned...there was a whining noise that was faint but unmistakably coming from my differential. The car was a CPO, so I took it to a dealership and the service mgr agreed, then he didn't, then he did again (the noise was pretty subtle).
He said he could have his best guy rebuild the diff, but it could come back better, same or even worse.
I said go for it...and his best guy was good because it was fine after that.
Not a common problem with the 996, but that's my story.
