New 99 996 owner. Spun rod bearing next day.
#46
Nice job again on the rebuild!
I see in your rebuild list that you replaced the piston rings.
Did you do anything to the pistons or cylinder walls? Did you measure the cylinders for oval and/or wear?
Any chance you would have pre/post rebuild compression and/or leak down numbers to share?
