Strange suspension noise...
Rocky Mountain High
Just this morning the C4S started making a strange noise. It only happens when turning, particularly at slow speeds. It takes a relatively sharp turn to make it happen, and it sounds like it's coming from the passenger's side front. It's a loud clunk. At first, it sounded like something in the trunk rolling back and forth and hitting the sides when I turned. There's nothing in my trunk. I just had my strut mounts and drop link bushings replaced earlier this year. What else could it be? Wheel bearing maybe?
wheel bearing is more like a grinding sound.
Have you checked to make sure the bushings are ok?
Sounds to me like you have a loose connection allowed something to pop when turning full lock
Rocky Mountain High
I'm going to have my mechanic check it out on Monday morning.
I just had my front wheel bearings replaced. Not too expensive but had to get an alignment.
The noise was more of a squeaking sound when turning at low speeds.
GL with repair.
GL with repair.
Rocky Mountain High
I just rolled 104,000 miles. I actually did check the lug nuts - they were fine.
I was actually wondering about the possibility of the CV joint... it will be interesting to see what they find.
Do you mind me asking how much you paid in parts in labor for the front wheel bearings replacement?
